I got a little time to work on it this week - mostly inspecting the front brakes, suspension and steering, ordering parts and removing the old fuel lines and FFM.
Today I tore into it further. I got all of the steering parts removed so I could swap the center link and pitman arm - while inspecting the steering I found that the pitman arm nut was loose (the cotter pin was holding it in place still) and the stud was loose in the center link. So I ordered a new center link, assuming the hole in the old one was messed up. The idler arm was also a little loose so that was getting replaced as well. I already had a Super Steer idler bracket that I bought shortly after I bought this truck last fall. I had planned on going all through the truck this winter like I did with Krovvy this spring and I was going to really beef up the front end. Now for some reason I totally forgot that the Super Steer part was only the bracket.....I was thinking it was an idler arm too. So when I opened the box today and found only the bracket, I thought I was stuck until I got an idler arm, but then I thought some more - Krovvy is more of a build than initially planned so the Super Steer bracket is actually a better fit for that truck. Plus the MOOG parts I bought for Krovvy are actually a more reasonable fit for the dually since it will be getting torn apart again in the near future and the Mevotech parts for the dually are better for Krovvy (YAAAYYYYY more parts to paint!!), so the idler and pitman arm got pulled from Krovvy so they could be installed on the dually.
The driver side outer CV boot was torn, so I yanked that axle after pulling the steering and took the joint apart for cleaning and inspecting. Evwrything looked ok so I picked up a Dorman boot locally. I know this boot won’t last a long time, but it will work long enough for me to use the truck for a while and then when it gets restored in the future I’ll get new thermoplastic boots from Rockford Constant Velocity.
I also got the accessories taken off the engine so I could yank the water pump. I’m going to put the balanced flow water pump and Hayden fan clutch from the Tahoe on this truck to help keep it cooler while towing.
The only things I didn’t get removed that I wanted to were the oil cooler, exhaust crossover, turbo and manifolds. I have to admit......I’m a little nervous.......right about now is where I’d get the brilliant idea to pull the front clip, yank the engine, paint the frame, yadda, yadda, yadda. I hope I don’t get any big ideas in my dreams tonight
