Hey fellas, having a weird starting issue and I was recommended to post here. Hopefully you guys can provide some input.
The truck is a 1997 Hummer H1 with the 6.5TD, and DS4 injection pump.
Last week when I went to start the truck, it would crank but not start. I cracked a line at the injectors and fuel came out. I didnt check actual pressure yet because I didnt have a gauge. I checked fuel at the drain valve and confirmed there was no water or contaminants in it.
After 4 or 5 attempts, the truck started and seemed to idle fine around 740 RPM. I noticed that if I revved up the engine all the way in park, it seemed sluggish and only went to 2k (not sure where the rev limiter is set. I noticed my check engine light was on. Scanner read P0251, which is injection pump, rotor/cam circuit malfunction.
I drove it into my garage, turned it off, and it would not restart. After cranking 5 or 6 times, it started, seemed to idle fine, but again would not restart when I turned it off. I threw in a new lift pump and fuel filter but no change.
I was told by a friend that it might be a bad optical sensor or injector pump? Any help or ideas? Thanks in advance.
