Hitch help
North Maine
Merchant Mariner
Fort Kent, ME
Hey guys, I *rarely* venture out of the 6.5 section, so I'm not familiar if this section has regulars etc, but I could use some help. I rarely tow, but I do have a tandem axle flat bed bumper pull that is a converted camper trailer, it's 16 feet of deck, ~20' overall, but this is all irrelevant, the issue I have is the hitch itself, I'm used to boats, so this locking devices is strange to me, but after looking online it seems rather normal, I just don't know how to secure it in the "down" position, with a boat i run a cotter pin thru the hole, but on this there is nothing locking it... I hope these pics explain a little better than I can... does anyone know if I'm missing something on this hitch and I need to fix it or am I retarded? thanks in advance for your help.
Here it is with the locking collar down...
and with the locking collar up
Excellent pictures...
Ive never seen a hitch like that. It almost seems as though its missing a locking pin.
Is there something underneath where the ball goes into that locks it into place?
Yes, when the collar slides down it locks the hitch to the ball, and when the collar is up the hitch can slide off... is that what you mean? it is easy for me to unlatch this thing, that why im afraid a bump might do it on the road... it would have to be one serious bump, but I like mechanical reassurance.
I've never seen a hitch like that either.
I would be concerned too. I like to make sure there is a positive locking device that will not allow it to come unlocked if you hit a bump.
Who converted the trailer from camper to flat bed?
It looks like they left out a tab or something with a hole so that you can slide a pin through that hole in the latch and lock it in place.
I've seen and used that type of hitch. There is suppose to be another piece inside that prevents it from coming apart when you put a pin through the two holes.
If I were you I'd have a welding shop replace it with a bulldog style tongue. They are sooooo much easier to deal with IMO. Or they may be able to weld the other piece back on that is suppose to be there.
Yup, most definitely missing a piece. I had a trailer with that setup in the past, and it had another part sticking up that the pin caught. Easy fix, do like you said and weld a tab down there.
