Demographics: tell us about your truck and your ambient conditions:
- Year: ___1997___
- Truck model and class (ie: c2500) ____k2500_____
- Automatic
- Mileage: (indicate miles or km) ____app__130k___
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) ______pmd_____
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? ______________
- Ambient outside temp: (indicate *C or *F) ________NE Ohio weather__
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) _____D2, wvo but not for years____
- What fuel additives are you using? ___________
- Where are you located? ____NE Ohio_________
General maintenance: inspect and evaluate the condition of each. When were they last changed?
- Air filter ____good_____
- Fuel filter ___recent______
- CDR Valve? _______?__
- Coolant – last flushed/replaced at _______?______
- Oil – synthetic/regular, changed at _____reg; ~ 1 year not used much with conditions______
- Batteries – state of charge, (matched set) replaced at ______depleted from fruitless cranking_______
- Battery cables and grounds (removed, cleaned and tightened): ________?______
- Glow Plugs - how many miles on them? ____not many, truck has been idle_____ What type? ______?_______
- Injectors - last changed at ______not known_________
History: (Describe how the problem first appeared.)
- What were you doing when it happened? ___mid July___picked up a washing machine, 80 mi round trip. Died in my driveway, hasn’t run since________
- How was the truck running fine before this problem appeared? ____did not get driven much_________
- Has this problem ever happened before? _______not to degree of not starting________________
- Describe any related factors that might be part of the problem. ______________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) __n__ And? ________
[FONT="]
[/FONT] Diagnostics:
1] Starting:
1a] Does the engine start? ____no_____
1b] Does the engine crank over? _____yes___
1c] Are your batteries fully charged? ___most likely, no______
1d] Have you removed, cleaned, and tightened all battery connections? ____yes____
1e] Does your Wait to Start light come on for a time? How long? ___Y, 3-4 sec______
1f] Does your glow plug light come on? ___yes______ For how long? ____4-5 sec_____
1g] Do you see smoke from the exhaust while cranking? What color? ________
1h] Does the Service Engine Light Glow during Start/bulb check? ________
2] Fuel Issues (if not running):
2a] Can you hear your lift pump working? ____yes________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? ______?___
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? _____?______
2d] Loosen an injector line and crank the engine - does fuel come out? ____?_____
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? _____yes______
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) ____remote_______
3b] Condition of Extension harness (if used) Vendor or Homemade? ______vendor___
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. ____?_____
3d] PMD Make: ______?_____
3e] PMD Age: _____< 1yr________
4] Stalling Issues
4a] Do you experience stalling only when hot? ____________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) ______
4c] Does pouring cool water over the IP seem to help with restarting? ___no______
4d] Is stalling momentary (engine recovers)? _________
4e] Does SES light come on when engine hiccups? _________
4f] Does cruise control quit working when engine hiccups? _____?______
4g] Does re-starting seem to reset engine, restoring cruise and power? ____no_____
4h] Changes to dash lights or instruments during stalling events? ____no_______
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? _____?__
5b] Any bubbles or oil film in coolant overflow tank? ____?___
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? ______no____
5d] Excessive white smoke from exhaust on cold start? ____no_____
5e] Excessive black smoke from exhaust under hard acceleration? ____no______
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? ____no_______
6b] Maximum boost under load? _______?_____
6c] Have you added a performance PCM (reflash) or Chip? ______________
6d] Have you changed exhaust / downpipe / crossover? ______no__________
6e] Wastegate – mechanical or vacuum (OEM)? _____oem_________
7] Temperature-related Issues:
7a] Single or dual thermostats? ____?_______
7b] Have you replaced them lately? Manufacturer of replacements? _____no____
7c] Have you pulled and cleaned Radiator and coolers lately? _____no_______
7d] Have you replaced the fan clutch? Manufacturer of replacement? ____no____
7e] (winter) Have you tested your antifreeze? Good to what temp? ____new, ?______
7f] (winter) Are you using a winter grille cover? _____no______
List and describe any other factors which are not addressed in this checklist. We can’t see, hear, smell, or touch your truck, so the more descriptive information you can give, the more likely it is that somebody can assist you.
