"DTC-68"
Sunshine
Northern Lights
Oslo-Norway
Hi to all... Still having problem with the ABS it`s throwing a DTC-68 Transmission Component Slipping..
What does this mean & what do i need to do so i`ll be happy again...
Thanks Guy`s
Means your TCC is slipping - but, faulty connectors and wiring give same symptoms as faulty device - get up under the vehicle and R&R all the connectors on the transmission - check for dirty, corroded, oxidized pins, etc - check for frayed wires, etc - clean and repair as necessary
Thank`s gmctd i`m pleased you gave it to me short & clear...
You are worth your weight in Gold...Take Care....
/Paul
This is a known issue on high milage 4L80E's. It deals with line pressure loss through the actuator limit valve. My 95 has the same problem. MIKE L from the other site told me about this one awhile back when I first got the 68 in mine. It could be electrical as well, or maybe you just need to service it.
Appreciate all the help so far....taking one step at a time, so now i`m up to checking the front sensors for rust, i need some advice how i`m going to remove the 4x15mm bolts hey have been drown in WD40 or are nuts off to remove the Rotor, they must of filled them with Red Loktite coz i`ve broken spanners & ruin a socket...Do i need to drill or TNT... & is it best to put it in 4x4 while working on this...?Thanz
