Pat79
Can any one tell me what models will work on it?
If the cooling lines are different, then its a 96 or older and will not have the 12 o clock mounting bolt hole.I found one but the cooling lines are different could I change my lines to the one out of the truck I'm taking it out of
If you're talking about a GM 6 speed, ot would cost a small fortune to make it work. 06 is a gen 3 truck(24x reluctor), and the 6l80/6l90 only communicate with gen 4 controllers(58x reluctor). It can be made to work, but will set you back some coin to do so.Pat, Welcome to TTS!
Ferm, why not a 6 speed?
