Looks like the thread ran outta room! So glad you guys are weighing in on my project!
So to continue this thread I started this new one.
Q: How hard is it to install a wicked wheel? . . . Any special tools
Great advise thanks.I have this engine - you take off the cross over by the six bolts - three each side - and then take off the intake and exhaust piping. You then hold the turbine shaft with the socket and take off the nut on the compressor side - which is left hand and put on the new one.
so . . . it is not hard at all . . . but if you are going that far in . . . rebuild the Turbo by replacing the cartridge here is a source => https://www.rockauto.com/en/moreinfo.php?pk=5784879&cc=1153325&jsn=526 $459 for the guts complete and then swap the wheel wheel on. OR . . . you could get a rebuild kit for about $26 - do it your self and then put on the wicked wheel instead of the stock compressor wheel. If it were me I would replace the turbine shaft and wheel just because I am in there that far if you do not but a complete cartridge
There are several videos on the web
One site here => says some things about the wicked wheel I tend to think defy the laws of physics but . . . anyway . . . https://www.dieselsite.com/wickedwheel6.5L.aspx
You could split the housing and replace only the compressor wheel - but you would be sorry if later you find the turbo needs a rebuild after you put it all back together - like it sprays a lot of oil out the bearings
Typical turbine shaft side pictured below. It would take a 12 point socket
ThanksAm sure that better experts will chime-in shortly. From what I had read, swapping the compressor wheel is supposedly easy, but then again had read that it does need proper balancing for long term health of the bearing.
Removing the compressor housing is definitely easy as it is just a matter of loosening one bolt and then sliding off the assembly. IIRC, it is either a 10 or 8mm socket for the job. Even a bean-counter like myself can do this part
One thing I would consider is to heat treat the up-pipes for both efficiency and preventing the heat from baking components around them.
Thanks
Any links to the turbo rebuild kit you mention?
Any recommendations for fuel pressure gauge. Brand name etc.
I like the idea of digital with duel selection. Lp and ip selection.
I used a boost guage for a fuel pressure gauge so I can see if it ever pulls into a vacuum.
I have to start by saying I apologized to Roy and SplitSsss for my bad choice in how I handled the disagreement. My response(s) on this thread are not to continue disagreement but at the request of SplitSsss.
@SplitSsss you sent me the PM and mentioned your budget.
Dual LPs have been done. My opinion is that I would put in a good aftermarket LP in. Do it in such a way that you can revert back to stock easily so if on a road trip you can get parts easily. I put in a raptor LP and didn't cut any stock fuel lines. If interested I have a write up in a thread here somewhere.
It is all good.
If you have a budget - look at my post to how to do the lift pump yourself - which should save at least $100 for the same rotary vane LP set up
There is actually gm dual lp wiring also - but if you use two fuel tanks - you can use either a rv solenoid to switch which tank to draw from - or set up an OEM lift pump as a transfer pump to put fuel in the tank with the gauge.
Remember -if you do not know if you do not use the other one of the tanks religiously algae could begin to grow from condensation if it is not at least kept full
