I'm running MaxETork also - the chip cannot vary the basic timing specs derived from mechanical IP position relative to crankshaft position - only the owner\hacker and timingtrain wear can do that - only the fuel rate curves within the timing specs can be adjusted with software, plus maybe the DESIRED timing within those specs - but never the MEASURED timing - I would doubt whether the TDCO relationship has been altered, also, as that is based on the camring ramping factor.
I wonder why my timing is 10.9 desired and actual with the HP4....
__________________________________________________________________
ENGINE SENSORS
Engine run time: 00:02:05
Boost pressure (MAP): 13.61 PSI
Desired EGR: 15.23 PSI
Desired idle: 656 RPM
EGR pressure: 13.63 PSI
EGR duty cycle: 0 %
Engine coolant temp: 191 F°
Engine speed: 638 RPM
Glow plug relay feedback: 0.1 Volts
Glow plug voltage: 0.1 Volts
Ignition voltage: 13.1 Volts
Wastegate duty cycle: 94.5 %
INFORMATION SENSORS
PCM Calibration ID: 4735
Current DTCs: 0
Accel. ped. pos. 1: 0.69 Volts
Accel. ped. pos. 2: 4.33 Volts
Accel. ped. pos. 3: 4.02 Volts
Barometric pressure (BARO): 12.76 PSI
Battery voltage: 13 Volts
Fuel temperature: 126.4 F°
Intake air temp: 96.9 F°
Throttle position: 0 %
Turbo boost (Calculated): 0.86 PSI
Voltage reference sensor: 1.3 Volts
INJECTION PUMP SENSORS
Actual injection pump timing: 33.44 Deg °
Cam reference missed: 0 Counts
Crank reference missed: 0 Counts
Fuel calibration: 115 Counts
Fuel rate: 9.38 mm³
Fuel rate - Cruise: 0 mm³
Fuel rate - Idle: 9.06 mm³
Fuel rate - Maximum transient: 69.06 mm³
Fuel rate - Throttle requested: 0 mm³
Injection pulse width: 1.8 ms
Injection timing - Measured: 10.9 Deg °
Injection timing - Desired: 10.9 Deg °
TDC offset: -1.94 Deg °
TRANSMISSION SENSORS
3-2 PWM solenoid duty cycle: 0 %
Cruise target speed: 0 MPH
Cruise speed error: 0 MPH
Current gear of transmission: 1 Gear
Current torque signal pressure: 31 PSI
Current transmission ratio: 1:4 Ratio
Error between desired and actual shift times for latest 1-2 upshift: 0 Sec
Error between desired and actual shift times for latest 2-3 upshift: 0 Sec
Force motor (PCS) - Duty cycle: 35.5 %
Force motor (PCS) - Feedback current: 0.62 Amps
Force motor (PCS) - Reference current: 0.62 Amps
Time of latest 1-2 upshift: 0 Sec
Time of latest 2-3 upshift: 0 Sec
TCC PWM solenoid duty cycle: 0 %
TCC slippage: -34 RPM
Transmission input speed: 692 RPM
Transmission output speed: 0 RPM
Transmission temperature: 162.5 F°
Turbine speed: 692 RPM
Vehicle speed: 0 MPH
STATUS FLAGS
Shift lever:
Park/Neutral
Cruise control:
TCC mode word 1:
TCC is being forced off
TCC enable solenoid valid
Low threshold for COPETCC selected
Use hyst. for vehicle speed
TCC is in release mode, slipping
TCC is in locked-adjust mode
TCC is being applied
• Negative slip recently prevents apply
TCC mode word 2:
TCC PWM is on
Perform release
Perform apply
• Min. threshold occurred
TCC Bus. is valid
NDT occurs
Delay is in progress
Min. throttle occured
IOD port A:
Glow plug relay - Closed/Open
• Stepper motor inhibit - Run/Inhibit
Service Throttle Lamp - On/Off
EGR vent enable - On/Off
• Shift A - On/Off
Shift B - On/Off
TCC enable - On/Off (4L60E only)
• Force Motor enable - On/Off
IOD SOD status register:
Coolant temp. pullup select - On/Off
Trans. temp. pullup select - On/Off
Fuel calibration temp. select - On/Off
Check Engine Lamp - On/Off
PWM1 - Reset/Normal
PWM2 - Reset/Normal
PWM3 - Reset/Normal
PWM4 - Reset/Normal
System status word:
FM shut off due to low battery
Force Motor pulse in progress
• Power is On/Off
COP2 is being serviced
Delco instrumentation PROM
• Powertrain is in motion
Discrete flags:
Brake - On/Off
A/C Compressor - Engaged/Disengaged
Power enrichment - Active/Inactive
Kickdown pattern - Active/Inactive
Four-Wheel Drive Low - Active/Inactive
Cruise low - Active/Inactive
Diagnostic - Requested/Not requested
