Sorry to see it all that bad.
Man this is about what my engines looked like after a bad day at the track trying to push 3 times the designed power and wanting a 6,000 rpm diesel.
So exhaust pushrods bent, pistons hit valves. Probably going to find all damaged exhaust valves and guides to match the push rods. I would not run those lifters after this. Cam needs a fine tooth comb to see if it is damaged.
Video on the timing chain would be interesting to see when it comes apart.
It seems like total timing failure or trying to do a 5 minute smoke show with the tires and didn’t know to not just ieepnit floored while roasting the rubber.
