FellowTraveler
ATTENTION CHEVY/GMC 6.2/6.5 DIESEL ENTHUSIASTS
CHEVY/GMC 6.5 TURBO DIESEL PARTS FOR SALE
SEE DEAL AT BOTTOM.
From a CHEVY/GMC 6.5 Turbo Diesel GMT400 K2500 L65 “F” TUNE built MAY 1999. These parts will fit other years however; the buyer is responsible for knowing what fits or doesn’t.
ALL PARTS ARE USED UNLESS NOTED (SEE PACKAGE DEAL BELOW)
SEE DEAL AT BOTTOM.
- AC compressor near new used a few months $30.
- AC manifold near new for front ac applications only $15
- AC accumulator for single ac “new” $8
- Engine accessory brackets R & L mounts ac compressor on drivers side top & has provision for dual gen/alt R & L top $40
- GEN/ALT DS130D have two (2) used and in good condition from my dual gen/alt setup $35 ea. or $50 for both
- PSC power steering pump (near new) for hydro-boost application part # SP-1404 $45
- INTAKE manifold upper/lower (non EGR) $40
- OIL fill pipe w/cap $8
- Oil line to oil cooler AN-8 to 6.5td block adapters, reusable AN-8 steel hose fittings “you need hose, fire sleeve (for run under exhaust manifold) and AN hose fittings w/adapters for your oil cooler to complete this setup” $50
- OUTER crankshaft pulley $15
- Turbo downpipe 3” to 4” stainless used in good shape $30
- RADIATOR shroud upper, lower w/upper brackets & rubber bushings $40
- VALVE covers R&L side $45
- CRANKCASE depression valve w/pipe $10
- OEM REMI starter brushes changed out not long ago $45
- Drive by wire throttle pedal complete w/position sensors $40
- Fuel lift pump “NEW” $15
- NP246 t-case controller w/4 button dash switch $25
- 9.25” IFS differential 4.10:1 ratio early model however; fits 1989 to 2010 K2500/3500 & cab chassis 4X4 $250
- AIR filter box latches four (4) stainless high for capacity cylinder filter box for L65 $2 ea.
- Almost new pressurized coolant recovery/accumulator tank w/fluid level sensor $40
- Oil filter adapter 90 degree $15
- Misc. injector bodies, springs, spacers, optic/temp sensors, late model pump core with good stepper motor, fuel solenoid etc. $100
- OEM Steel wheels five (5) CHEVY/GMC high capacity riveted & coded at valve opening “not the lower capacity welded type” 16”x 8 lug w/expired DOT date tires $125
- 6.5td Glow plug relay fits 94-02 $30
