Chevyfan
hello I have a 1996 6.5 turbo diesel 4l80e 2500 ex cab 4x4 I got truck on a trade it ran like a top it was after confirmation the 4l80e was bad decided I didn’t want to rebuild so I bought a standard transmission and converted my 4l80e to standard put shift position indicator on frame in Park position plugged in plugged all trans case wires back up and put main 4l80e plug on frame (not plugged in) now theirs no fuels at injectors so I bleed system at fuel filter housing then t handle try injectors again still dry so I pull plunger from injection pump it’s not opening but getting power with key I run a ground wire straight to batt to it now when cut the key on it works as should try injectors again nothing so do more research and learn theirs another shut off type sensor on back of pump so i think wat ever is telling plunger not to open is same thing shutting it off do more research find pcm is very common although I have a relocation kit I still replace with new pcm try again still dry any help is greatly appreciated thanks and god bless
