RobC
i have a 05 GMC Yukon Denali My Voltmeter runs between 9-10 but when I turn my headlights on it goes to 14 and stays there. I did replace the alternator with one from Napa and it did the same thing. Any thoughts
That system was NOT used until the LML IIRC, and even then it was NOTHING like what was used in gassers to satisfy CAFE standards. The only input the ECM or any other controller has on an LLY is to supply the alternator field after the engine has started, and monitor the charge output to turn on the battery light in case of under voltage or no alternator output. So disregard EVERYTHING in regards to the rvc. I don't think GM even used that system on anything but 1500 and down.First thought is everything is normal for the goofy RVC GM used for these years. The "OMG!!! The alternator quit I am going to walk" volt meter reading is common and normal. Really need a deep cycle battery in these rigs. GM cuts the alternator out to save fuel when the battery is charged and the loads are low. Headlights on bring the voltage up for brighter headlights. Many modes.
https://noln.net/2017/03/28/battery-management-challenges-smart-system/
You might need to service the gauge cluster as the swatch gears used are all shot. Known issue for these years.
Yes, get a real voltmeter or one that plugs into the cigarette lighter that reads volts. (Idiot light style are useless and are sold.) Harbor Freight is good enough. Measure voltage at the battery etc. FORGET ABOUT THROWING PARTS AT IT LIKE ALTERNATORS!!!
Oops, I seen 05 and thought lly, but I'm not sure if the rvc system even made it to 6.0l's(most Denali's I've seen have been 6.0l's, but I know some got the l33 5.3l). Last I heard from Ben it was only 4.8/5.3l that got the system. It was only models that fell under the cafe standards that got it. I would have to pull a tune file on one to see if it's enabled or not.@THEFERMANATORPretty sure a "05 GMC Yukon Denali" the OP is working on is a 1/2 ton and not a diesel. The headlights going on and higher voltage reading is a good clue it has the RVC system.
It never hurts to test the battery and clean grounds as the system is hard on batteries. However the volt gauge swings are large with the system so again may be normal. That's one gauge GM should have numbed to "idiot light" from the get go.
