Posted elsewhere I had installed a 6micron fuel filter in the engine bay as a stop-gap to use with an OEM Lift Pump after the Air Dog failed. More of a mock up mounting really. I have it mounted over the Power Steering Pump on the A/C bracket. The assembly was held in place by only one bolt which also holds the radiator hose support. I wanted to make up a bracket for a better hold since one bolt, over the serpentine belt and pulleys...not a good idea for anything other than checking fitment.
Since that mock up was a week ago, Thursday I got an "L" bracket at Home Depot, cut it down a bit, marked and drilled holes and then gave it a coat of paint.
Bracket is held in place with the larger OEM bolts and the filter mount is attached with two bolts so it won't rotate into the pulleys. Bolts are secured with Nylon Lock washers. Should work for the foreseeable future.
Hose protector on the radiator hose to keep the braided lines from inadvertently sawing a hole in it.
After I got done, my granddaughter came over to 'help' and so I had her help put together a line plug for the Air Dog's return line that runs back to the fuel filler neck. The line was open and venting to atmosphere meaning contaminants, water and such could get in and, when filling, fuel could get out. She really liked the big wrenches and did great.
The plug I built out of spare brass fittings was a cobbled up solution consisting of three parts. 1). 1/2" brass hose end w/ 3/8" NPT-F threads. 2) 3/8"NPT-M to 1/8" NPT-F threaded adapter/reducer and 3) 1/8" NPT plug.
Once it was done, I took her out to the truck and had her tighten down the hose clamp holding it in using a 1/4" drive socket and ratchet. The flat blade screwdriver was too much of a challenge. Proper tool for the job and it fit her little hands.
"Train up a child...." Love this little girl.
