ak diesel driver
6.5 driver
What kind of posi does my dually have?
Have You tried changing the lube ?So will it damage any thing I wouldn't be replacing anyway if I let it go for awhile?
Well, that is good news.Put a full tube of additive in and so far so good
GM does not require the friction modifier like others since the clutches are not pre loaded. A G80 is only supposed to be active once wheel speed is between 10-25 mph, and there is a 50(don't remember the exact number, but it's quite a bit of difference required to engage the flyweight) rpm difference between the 2 tires. Alot of people let out of the throttle thinking they're broken before the wheel speed ever gets high enough to engage them. Then theres those who hammer them trying to lock it in, and exceed the speed it will work at.Have You tried changing the lube ?
I`m not sure about Your locker but the one I just rebuilt for My son, in a 2000 dodge 1500, it required some differential friction modifier that keeps them from making noise and being so harsh.
Get it out. Also of note, the 10.5" rear axle uses steel clutch plates full of holes, not a clutch plate with a fiber type clutch material. They are supposed to provide more holding during situations when the G80 is unlocked. GM even has a tsb stating the 10.5" may chatter or feel grabby during parking lot type situations, and that it is normal expected operation for one to do so.Put a full tube of additive in and so far so good
