Let's revive this thread, shall we?
Work has commenced on building an OEM-appearing center mount turbo setup.
I took my van manifolds to a local machinist who touched up the faces of the v-band flanges and cut the rear faces to sit better in the clamp. Appears to seal well so far. Flanges are just $20 eBay specials that I ordered. Seem to be decent quality. Anyway, the manifolds got blasted as well and are dummy bolted to the 6.2 for us to begin mockup. I need to order bellows for the up pipes and also try to source some pipe stock that has a thicker wall than standard exhaust pipe, for heat retention purposes. The up pipes will be wrapped anyway, but as we all know, every detail has to be correct to help these engines make any kind of power.
Yesterday we traced an intake manifold gasket to begin making a custom intake. We used 3/16" which I think will be thick enough. The machinist will likely get the finished product once it's all welded to face it and make it totally flat.
Not much else to report for now. Slow and steady.
Sent from my iPhone using Tapatalk
