Is the FASS flow on fail?
I thought I'd do some self education and spent some time looking over the FASS web site and googling 'DRP-2, Flow on Fail.' I've attempted to put my research down in this long and, seemingly, unhelpful post. For those without the desire to endure my banter...
BLUF: Nope, no answer I mean. Going to have to call them cause there isn't much other than an install manual with basic flow info on their web page for the DDRP-2. Either that or try the Dodge forums with the question.
I haven't tried but they have a tech line and a dealer system you can ask thru. I have a full list of parts and fittings for a complete system you should be able to find via the Google with my user name.
When I googled "Fass DRP-2, flow on fail," your excellent write-up did pop up (I read it when it first came up, nice job. You ought to copy it over here too). Anyway, the primer verbiage said, "A simple flow-on-fail backup in case of pump failure; Replacement parts readily ...FASS DRP-02 High Performance Diesel Fuel Pump." ... time to pull the fuse and see if you got what you hoped for. ;-) poke poke. I know the AD I'm running is flow on fail but that's another thread.
Other results that came up on the search were threads that talked of Carter "Fail" and addressed "flow" but nothing located as to 'flow on fail.'
Owner's manuals linked on their site (
http://www.fassride.com/fasstech.php) list the Titanium (LT Truck), Platinum and HD (Lt Truck, HD Equipment & Semi) but nothing save an install manual for the DRP-2. Unknown by me if the DRPs are part of those three families but it doesn't have the water, air filtration systems either...Odd that they don't list an owners manual or that the install manual for the DRP doesn't have the info either.
The HD and Platinum manuals states that, "In class 8 set ups, the FASS series is equipped with a by-pass port that allows the engine to continue running in the event that a problem occurs and the situation calls for the unit to be by-passed. At which point only water and dirt are being separated." Since we aren't running Class 8 Semi's here, that's not much help.
FWIW, The Fass 150 is flow on fail as demonstrated
But, it is twice the price of the DRP-2....
