C20ELEPHANT
Member
Soak it with your potion, hit with the heat wrench, then the pickle fork and a BFH.
Not a fan of the BFH method and a pickle fork will not work for ball joint removal.
You'll be happy you did, with joints cooled down in freezer I used a 3/4" drive ratchet with ease......
The ball joint remover arrived today and was a bit surprised as to how large it is. Should be able to remove the leaf spring bushings with it as well, not liking the idea of using a torch etc. I found this video which prompted me to rob my mad money car truck account. When I installed rear shackles on the rear to lower it the bushings were flat and the time has come to either downsize and sell the truck or keep it.
You tube video for leaf spring bushing removal.
I had considered this press.
https://www.amazon.com/dp/B00DWB1MTM/?tag=jhuntlink-20
