Hink
Overkill Is Underrated
This is one of those things that's nearly impossible to diagnose long distance but I'd really like your guys' expertise here.
The scene...
1- Towed the RV home from ND running warm but never overheated, only got real hot a couple times and only for a few minutes at a time, never ran long at all at hot temp.
2- Took the hood off to get vents put in and see if it helped to run cooler, it did.
3- Got home fine, drove the truck for 3-4 days and everything was great. Started quickly, ran great and shut down fine every time with no odd noises.
4- Drove the truck two nights ago a bit in the day, still ran fine and shut down fine. It sat for a few hours (2-3) and started great when I went out to move it a hundred yards or so and shut down fine.
5- Next day when I tried to start it, it was locked up. Not "it won't turn over because the batteries or starter is bad" but locked up.
What I did...
1- Pulled the fan shroud, fan and pulley off to get a wrench on the crank bolt but it wouldn't turn.
2- had a buddy come over to pull me to the hill, rolled down and popped the clutch, she just skidded. (Road was wet though)
So I'm thinking it makes no sense but it looks like I'm screwed, but then my buddy said that it actually moved a little when I hit the key, so there could be hope.
Today, I pulled most of the front of the truck off to get better access to the crank bolt and sure enough, I was able to get it to turn. No great effort needed, just a good pull.
One other weird thing... I tried the key again this morning but the batteries were real low and the clicking you hear when engaging the key stuttered real fast and loud, that's the best I can describe it. So I put a charger on it and that's how she sits.
The only two things that I can think of is
1- Heat caused damage to the motor and it seized. But that makes no sense because I drove her fine for several days after returning. It literally happened overnight.
2- Water entered the cylinders and hydrolocked her a bit. But really? just because of no hood for a few days? Thousands of hot rods have been run without hoods for years with no issues.
(I'm discounting starter/battery issues regardless of the odd clicking and low battery since they were bypassed when I tried to pull start it)
Tomorrow I'm going to pull as many injectors as I can and see if I can line up help to pull it for a bit in gear to see If it will rotate freely. If she does, I'm sure there's hope, if not I really don't know what I'm going to do. I put $8000 in a new engine and tranny to do it right so it'll last. I can't be doing it again.
Any thoughts? Unfortunately in my life right now I could use a few miracles. I already got one when my fridge fixed itself, so that's a plus.
Thanks guys!!
			The scene...
What I did...
Thanks guys!!
