n8in8or
I don't know the answer to this. Thank you.Does anybody know if the 80s trucks have more room near the firewall for a center mount setup?
Btw nice job on the fab work!
Thanks 6.5L. So yours is on the road?I know how ya feel with all the cutting and welding and getting stuff to try to fit. I just went through all that. Insane amount of headache. I hope your results came out as good as mine
Oh the gauntlet has been thrown down!!! HaYeah. You got to get yours going now haha
Ok the fab work is done. Some of the welds look a little funny because I used the MIG to build up a couple areas so I could port them with a burr. I'm happy with the results and I think it should flow well. I decided to throw paint on it now to protect it from rust and also if it does fit without modification then all I have to do is put wrap on it and paint the wrap....this will save me some down time.Well since I won't be sending you my Swag table....I don't think I'll be able to accomodate the second part of your request.When you send me your Swag table could you include a copy of this header too? Thanks.
Thanks FT. I hope it is.That's an excellent setup........
No there isn't room for the OEM return line, but there is room for a slightly modified return line. My return line hasn't been stock since I swapped the HX40 on, so that doesn't bother me. You know, I had forgotten that I needed to come up with the drain line solution, so thanks for that......I think........I've a question that I hope doesn't kick in an 'uh oh.'
Will there be clearance for the Turbo's OEM Oil Return Line or will that need an aftermarket solution?
