From what I can find(all I have is my 95's diagrams, so the wire colors may be different from OBD1 to OBD2, but they are both the same body style so should be very similiar as far as wiring goes), the orange wire to the brake switch is the power feed from the fuse panel for the stop lamps, and the white wire is the wire that should carry the brake light's power from the switch. This wire goes to the turn signal switch, and it sends the current back to the rear tail lights. If you have a center high mount stop lamp(3rd brake light), it will be powered off of a splice in the white wire BEFORE it goes to the turn signal switch.
This is a picture of the brake light jumper harness connector. Theres about a 6 inch or so long harness that plugs into the actual switch, and this is the connector that hooks to the body harness. It is reccomended to do all testing at this connector instead of the actual brake light switch. From what I can find, this is what each wire should be. I'm not putting which cavity each should be as there is conflicting info as to which is which for the C, D, E, and F, but A and B seem to be for the brake lights in everything I can find.
orange is 15 amp power supply for brake lights
white is brake light power out of switch to truck. Goes to a splice point where it branches off to turn signal switch, ECM, ABS, and 3rd brake light
purple is the ECM feed for the normally closed side
brown is the power for the normally closed ecm feed
green is power to the switch for the shift interlock solenoid
green white stripe is power to the shift interlock solenoid
