96 6.5 suburban plz help
God I hope so thanks guys but how do I debunk that issue I've never worked on or with theft protection for obvious reasons lol
I gotta leave it inplugged for now I think 9volt is dead and key fob has no batteries in it
That's the wire harness top and bottom of ecm and front and back of AL-100 alarm box
I bet the aftermarket bundle runs to the driver's side and sloppily ties into the ignition switch wires. Likely there is a splitter on the starter wire without separating the actual wire (it cuts the wire and sends it to a relay). More or less follow the wires and undo the damage/install. You can rip everything out just looking for the cut wires that tie into this.
Don't forget glovebox lights and bad dome light door switches kill batteries as well as map lights that don't work till they get cold.
Ok under the dash is a cluster#\'( of amateur electrician stock after market security system trailer brake system and wires going no where used a code reader to see what's up and this is what I got
So any one have any opinions on this any would be greatly appreciated [emoji28]
Strainer stock looked alright but lift pump looked cheep and a knock off with heath heavy duty sticker on it
What bout those codes because I can get it to turn over all day long but no fire plenty of fuel especially now with new lift pump either the new used pmd I just got is bad or relay is bad I thank
I believe your electrical mess is a lot to do with all, or at least most of those codes. I would focus on getting the wires back to what it should be, then clear the codes and go from there.
On the invisible gold plated "new" parts- wow. Where did that come from?
