SnowDrift Ultra Conservative. ULTRA! Messages 3,397 Reaction score 4,712 Location Central Ohio map dot Feb 13, 2015 #21 Can the heads still be removed without pulling the engine with studs, or does that go away once studs are used?
bowtiebutler956 Active Member Messages 581 Reaction score 207 Location Harlingen, Texas Feb 13, 2015 #22 SnowDrift said: Can the heads still be removed without pulling the engine with studs, or does that go away once studs are used? Click to expand... Yes they can, but you have to remove the studs. The ARP studs have an small female Allen head on the end of them for removal, but if you were to use red locktite, you would end up rounding the allen head out before they would come out. Matt
SnowDrift Ultra Conservative. ULTRA! Messages 3,397 Reaction score 4,712 Location Central Ohio map dot Feb 13, 2015 #23 Good information on the studs. Safe to say I wouldn't use Red Loctite. Living in Ohio most of our Loctite comes from road spray in the winter.
