3500_6.5
Here is Joe's reply:
That delta cam is a remake of the old Crane camshaft that had running issues. The problem with that cam design is there is only 1 lobe profile for the entire cam. These engines require different lobe designs for passenger and drive side, which is the way the cam is done from GM. When you have 1 lobe for both sides it causes the event timings to be off from what they should be, and you have a cam that makes less power and has drivability issues as a result of that. The Delta or Crane cams are ones that are ground in such a way that we cannot even use them as a core cam.
Our HT4 Performance cam is one that has 4 different lobe designs, 2 for each side - an intake and exhaust lobe. That allows the cam to treat both sides of the engine differently, optimizing performance.
Similar to gas race engines, you'll see them having upwards of 6 different lobe profiles to make everything work to it's very best.
The HT4 Performance cam that we offer is one that makes 20+ HP and 40+ FP at the flywheel, and also lowers the exhaust temperature dramatically. We've also had many repots of 1-2, and sometimes more, MPG gain.
Let me know if this helps!
Hmmmmm
Some food for thought on the hp/tq claims with their cam: if you check out his website it gives those hp claims as well, but it says it requires a tune to get it. But on the other hand, you can buy just a tune and get more hp and not have to change the cam. So why buy a cam and the tune to go with it if you can just buy the tune for half the price and get more power? I love the fact that there are people out there still putting out products for these engines, but just be careful on the products you buy.
There is one vendor who does give the specs of the cam he sells though....good ole Walt from SS Diesel. Everyone's favorite vendor lol.
And as far as ds4s and fuel output, I went through that whole mess a little over a year ago. I was told they could put out 120 mm3. I mentioned that to a vendor, and instead of saying that it wasn't possible, he told me he has a special "race" tune that wasn't for the average 6.5. It had to be built to the hilt and required a plethora of gauges. I told him what I had planned and he told me he would get me the tune.
8 or so weeks later I get the tune and what do you know, scanner is showing 79.x mm3 and feels no where near where 120mm3 of fuel should feel. So I talk directly to the programmer and he says 120mm3 is not possible. So I got robbed of $350 or so by being convinced I was getting something I wasn't. The programmer did say he estimated that I was getting somewhere in the 105mm3 range though. Meh, still not convinced.
A few months later I get my hands on my old marine db2 and decide to rid my truck of the ds4 and swap the db2 on. Has roughly the same power up top, tons more down low. Long story short, I send it off to be beefed up and find out it was only putting out somewhere in the 80ish cc's (same as mm3) in the 3000 rpm range. So basically my race tuned ecm was still putting out the roughly 80mm3 the programming only allows for. If you want more fuel than that, don't believe the hype of any of the vendors, they can't get it. As stated by great white, a db2 is the only way to go to go beyond that 80mm3. Best thing about the db2's is that all the builders will give the output. No guessing, assuming or theorizing. It's tested on a bench so you get real numbers. Just wish I came across that information a year and a half ago. Would have saved me some money and lots of time.
Sent from my iPhone using Tapatalk
