Fender: No Snorkel in either of them. Drilling out the rivets, as mentioned, created damage to the vent that, in my opinion, negates their re-use on this project.
Drill Bits didn't hold up so well either. At least the Hood Vents fared better and will be re-used, after media blasting and powdercoating, on the truck's hood. That hood will be swapped out with the Tahoe's
Only real damage to the Tahoe's hood, is where the deflector has been rubbing. As the truck is getting repainted, it's moot compared to the dents and bends in the truck's hood.
Cleaned up the firewall, removed the door vent, Coolant Reservoir, assorted nuts and retainers and loosened one side of the AC dryer. Templated and cut out the holes on a complete section of RAAMat and stuck it on.
Re-installed everything over that portion. Wow, one section done without set backs.
View attachment 43156 Not sure if I'll add a black insulation barrier as well since the RAAMat alone cleans up very well.
Cleaned up the front portion of the frame and crossmember with a wire wheel and shot it flat black.
View attachment 43154View attachment 43155
Just need to get the tow hooks cleaned up and resurfaced and they can go back on. So, the front 12" are done. Now to address the radiator and A/C Condenser Fins with the Radiator comb and clean things higher up.
Obviously, there's more to do further back...another day.
I did get the Nerf Bars under the cab removed so I could have the access to get the front cab corners addressed. The passenger side has been cleaned of surface rust, treated and primed. Not sure I'll reuse the Nerfs though, there's some pretty deep rust on the brackets.
