Got a bunch done in last few days here are a couple mods you might consider.
The purpose is to remove the heatload off the cooling stack and hopefully increase A/C effeciency.
I putting in some effort now to remove as much heat from condenser and radiator now as I have a 2000# camper on the back and plan some trips though the Rockies. I don't wont to overheat. Some of the other mods Im doing but will share in another post are DE exhaust system, 2000 water pump, fan clutch a Dmax fan.
The engine oil cooler went in easily. I used my standard engine Oil cooler hose kit, but instead ran the hoses to the rear. The cooler landed right by the LP. Im going to install a puller electric fan on it. the cooler sits about an inch below the floorboard so a puller will draw heat away from the truck.
In this pic you can see the short piece of unistrut, I used it to space off the cooler from the floor. I used existing seat bolt holes, but had to intsall longer bolts.
Im not positive if this would work on a 4x4 the way I did this, but I'll look tomorrow and see if a 4x4 oil filter adapter will clear the hoses in this config.
