Bernie
Amateur Radio Operator - KJ4VOV
So it's 18* outside, the truck has been sitting since I parked it last night. I need to go to a meeting at the Red Cross so I plugged in the block heater two hours before and... it won't crank fast enough to catch. This has been an ongoing problem for the last month or so and I'm tired of it. The batteries in the truck are less than 2 year old Kirkland's. They were replaced under warranty in the summer of 2012 after my alternator fried and I damaged both batteries by discharging them too low. (I was the tail "chase" vehicle for the USMC Historic Half Marathon and all the warning lights on the truck were in use while creeping along at 4 mph - which was too much load for the system to handle at that low RPM) The alternator and all the cables were also changed at the same time, and the alt is a 140 amp unit, not the stock 100. So the charging system and the cables are known good, and if I put a charger on the truck for half an hour or so it will eventually start. Definitely the batteries, which sucks because a) they're so new, and b) money for new ones is tight right now. (Oh yeah, there's a cutoff on the truck so I know it's nothing inside that's draining the batteries)
So what are some good batteries these days? When I bought them the Kirkland's were very highly rated, 800CCA, made by Johnson Controls, etc., etc., but it seems the quality is going downhill now. Some folks I know swear by the Wal-Mart Maxx batteries, but others I know swear at them. If cash was no object I'd just throw a pair of DieHard Gold's in there, but that's $300 worth of batteries and I just put $1,100 worth of tires on in December.
What do you folks suggest?
