Grounding the Blower Motor
Deranged
United States
Great site and a plethora of knowledge abounds here. Just can't find this one little thing...
I inherited a 1996 Chevrolet 1500 x-cab w/ the 305 and Cheyenne package. Needs minor things done to it here and there and this is one of them I am almost finished with.
A/C Blower Motor not outputting as much air as it should:
The forum about the melted connection behind the glovebox solved my "speed" problem with this truck, however, I want to be as thorough as possible and add another ground as was advised. I don't know what it is I am to be grounding though. Am I adding another ground from the blower motor to say the frame? Is it one of the 2 wires coming off of the blower motor; i.e. the purple or black? I have basic electrical knowledge and can follow guidance well, just need to be shown the way.
Can someone explain to me what I need to ground to ensure that my new connection does not melt? Pictures would be extremely helpful.
Thanks in advance!
Deranged
No pictures. Sorry.
I always make a double spade connection at the ground lug on the blower motor. There is a dash mount bolt just a few inches away from the blower. I believe it has a 13 mm head. I use a 3/8" or 5/16" eyelet and go there with 10 ga wire. Even though it's overkill, I use 10 ga. or heavier wire for most added grounds
No pictures. Sorry.
Thank You! Now it makes sense. I had it in my head that I was looking for something else. This makes perfect sense. THanks!
I will add that ground tonight or in the morning and read up on that link as well. Thanks for the info guys, definitely humbled to be around so much knowledge.
Deranged
