Will,I did not try fitting the gm-6 turbo with the truck manifold, but thought about it. Coming out of the turbo to inter cooler, back to intake. The truck intake definately flows better than van. Then with your pedestal mount no drilling the block. Hose connections to turbo means no intake problems and no need to swap heads. The only difficulty is rework intake tube to turbo and up pipes.
If I understand correctly, you think that the crankshaft may be crooked isn't it?Balancer is done, replace it.
As for the first bearing pic, that to me, means the crank isn't true or the line hone isn't true, so I'd be getting the crank checked first, if its ok, your going to need the mains checked/honed for straightness.
This is bad news, mr. Turbovanman. If you are rite... replacement crankshaft?Yes sir.
I have thisAbout the oil feed and return, I forgot to mention- you do not need to use the factory location where the center mount turbo gets and returns it's oil. If you make a hose 1/8" npt thread it will screw into the block at the oil journal in the valley and can feed a different turbo from that. Then the return oil can dump down into the side of the oil pan with a through fitting. That is unless you already have a turbo already. If you do, post pictures of what you have.
Did you put this shaft?If you do, post pictures of what you have.
OK. One question. Have I use oil recirculation pump? Or will be enough stock of oil pressure?No on gasket kit. You want Felpro or Victor Reinz gaskets.
Yes on oil pump drive (oil shaft).
the gm6 is your turbo, same as vans and hmmwvs/ hummers. Using your spacer podium, run the return line on the passanger side down to the block off plate where a mechanical fuel lift pump would mount. Just drill and tap the plate. If you look online you will find pictures of these, this would be easier than doing the oilpan.
Thanks from future readers! :thumbsup:one thing to note for future readers is not all gm6s are for center mount. I have a gm6 on my DD from the factory
What do you think about PMD Dipaco?No on gasket kit. You want Felpro or Victor Reinz gaskets.
Ok. Tomorrow I'll make a pictures. But I think that it's a stock oil pump.No recirculating pump. You do need a high volume oil pump, it has the spacer in the pump body. If your not sure what you have, post picture of your oil pump. I will try to find pictures of where to drain oil to.
