The engine will idle for extended periods just fine. Your combustion won't be as good at idle and you'll get a small amount of fuel dilution (generally only detectable in oil analysis). If you want a bolt-on turbo kit, go with the Banks sidewinder. I've put them on 3 CUCVs and am getting ready to do another as we speak. The only thing you'll need to do on a CUCV is relocate the battery tray that goes over the right fender well since it will interfere with the turbo. If you haven't already, check out the Steel Soldiers website. They have a CUCV section and you can download all of the technical manuals from operator to overhaul. You won't find CUCV electrical parts very easy but there's a company called CUCV Electric who makes the circuits boards, relays, etc. and they are both reasonably priced and vastly superior to the originals. CUCV Electric also has a bunch of great troubleshooting guides. When you are starting your CUCV, always, always, always wait for the "Wait" light to go out. If you don't, you'll smoke the controller circuit board that's under the dash near the fuse box (CUCV Electric sells an improved one, by the way).
