Im refining the build up of them as I go. Yours will probably be the only one built like that. I wanted to try it out, it works great, but adds to much time/$$ to the part. So you got the "one off" collectors version #1.:hihi:
There were no issues with any of the kit items for the ATT or the Spacer. Hope that wasn't implied in my comments. We just took our time and had fun, for the most part, doing it. Delays came from the banter, side bar conversations (trucks, guns, joy ride, repeat).
Leroy, the spacer was here when I got back last night. I thought you were joking about painting it purple...Hilarious. Thanks.
Yes Mike (BtFarm), we know, got it, thanks, move along....:nana:
I like the build up for the rear, outside bolts negating the need for the washers.
I got JayCPA almost done too. Its going to look really nice. I have the MAP and IAT sensors mounted, just need to install the caps.
I didn't speak up because I don't know how much is the same besides tranny, but my hummer started doing that w/ the speedo about 3 days before I downed the truck over 7 ( 8 on hummers) bad ball joints, pitman, idler arm. No clue as to why its doing it (all my grounds are way perfect), but I put in input and output sensors 10,000 miles ago over different issue. If I get to work on it and figure it out I will let you know what I find.
Burning oil
ATT with I/C ???
Food for thought.
Attachment 39945
Attachment 39946
Attachment 39947
Burning oil
Couple more installed.
Attachment 39933Attachment 39932
