Old thread but synthetic Rotella 5w40 all the way. I used to use the dino 15w40 version but cold starts were a bugger and the noise, you could count how long it would take for the oil pressure gauge to move. Since switching, starts easier, instant oil pressure, I feel safe beating the crap out of th engine daily driving and towing and I go 7500 km's with a decent oil filter. I had the pan off at 180K and bearings looked good.
Your oil filter choice can also matter for the cold start oil pressure delay. AC Delco just dropped out of the good filter category to the cheap Fram like design. This means the anti drain back valve in the filters like Fram may as well not be installed because they don't work. Your engine clatters longer filling the oil filter back up. Silicone valves like Wix and Mobile 1 are the way to go.
Synthetic oil use is almost guaranteed to leak out of the 1990's oil cooler lines at the crimps. Gas or diesel engines. Even NEW GM hoses would leak synthetic. GM has since changed the design a little, but, I found synthetic still gets them.
I have had better oil pressure recently with a 15w-50 synthetic blend. A straight weight oil in our warm climate on long hauls without viscosity improver to break down is a good idea. (As someone reminded me of. :thumbsup: )
IMO the engineers mentioned weren't playing with a LS2 in a Trailblazer SS or Corvette lacking a oil cooler. There is a clear winner when temps get high (like 300 degrees oil temp) and that is synthetic. Yes the application needed an oil cooler and yes the GM bean counters were too cheap to install one. Yes, the hot running LS2 spits out rod bearings at an early age... Sludge failures plugging the oil pickup screen from specific Toyota and Dodge engines is reduced with synthetic oil use. The sludge, best I could tell from reading about it, was from high temp areas in the engine.
Step up to emissions strangled Duramax engines and you are running the fine line of what a conventional oil can handle. I did run that fine line and did go over it. The low oil pressure stop engine comes on at 9 PSI and I did see that warning on a 115+ degree day after towing. I am not sure how it would have done without the extra huge engine oil cooler. There was room to tow a bigger trailer. From a cost standpoint conventional did the job for 115K. Cost for my bottom line was the ONLY reason I didn't run synthetic. Only a few samples came back 'bad' like low viscosity with the warning message oil. We were running near 10K miles per the oil life monitor and can say it is fairly accurate. Change the oil when you suspect an issue.
In summery conventional oil can handle 90% of what is out there and use. When things get "extreme" like hot outside and you are towing hard or running hard in the mountains this is where synthetic could do you some good. Hot idle with the AC blasting stuck in traffic is also hard on engine oil.
MPG and other benefits left out of the discussion.
