dirtwork
I have been having a ton of white smoke issues after startup on my 92 6.5. I just got the truck so after a little investigating decided it was time for new injectors (looked to be original at 181k) and the glows were the original 9g's. The truck would start up easy, but white smoke (eye burning unburnt fuel smell) and rough running and miss until it would warm up, anywhere from 1 to 3 minutes, or more, depending on ambient air temperature. I got the new injectors, and 8 new Duraterms installed yesterday. When we fired it up the first time it started remarkably easy (within 5 seconds) and only a puff of smoke. Ran relatively smooth with some spit and sputter but after 15 minutes of idle time was smoothed out just fine. Shut it down and let it cool down. Went to start later on and we have smoke again. Not nearly as bad as before the work was done but still not right. Clatter is a little louder than before too, which I would expect some with new injectors. Its kinda acting like air, but no leaks, good LP operation. I have only driven it about 2 miles, so not sure if it just needs 'run" a little. Strange that it was fine the first startup after the new parts and not now. Once its warmed up really good it runs great- both before and after, but throttle seems crisper now. If its shut down and started up warm or hot fires ups with a bump of the key. I tried to disconnect the ECT sensor but it seemed worse. Almost seems like it runs better when the cold advance is on. Truck is not rusty underneath and lines all look good.
Thoughts?
Thoughts?
