Going to see how the tune/turbo combo affects your mileage in various scenarios, like if it improves, and if so how much and what the final numbers are for the different situations, ie: towing, city, highway, combined?
Yes, that's the plan.
I've talked to Slim and he's prepping a new turbo to send to me.
I'm also going see about getting some dyno time in.
There's one big caveat to my set up. As it is, I am running a 5521 tune on a 5068 pump. Neither Slim nor I thought it was possible, but my truck is running well. How well remains to be seen, I think.
If I run it on a dyno, here are the configurations I plan to run:
- Stock chip and 5068 pump with GM-4
- Stock chip and 5068 pump with ATT
- ATT tow tune and 5068 pump with GM-4
- ATT tow tune and 5068 pump with ATT
- Stock chip and 5521 pump with GM-4
- Stock chip and 5521 pump with ATT
- ATT tow tune and 5521 pump with GM-4
- ATT tow tune and 5521 pump with ATT
Additionally, I am considering hooking up the horse trailer and throwing some dead weight in it and towing for say 100 miles under each of those scenarios. I would log ground speed, distance traveled, altitude differences (using a GPS), max EGT, and number of gallons consumed for the run.
The goal would be just as you say: Under each of those configurations, I would be able to establish a rough idea of where the numbers fall. Obviously only extended use under each scenario would yield a solid benchmark, but I'm not interested in spending a year or more trying out each of those configurations.
What I will say is that so far I'm happy with what I've got from Slim. Spend about an hour on the phone with him tonight trying to figure out why I couldn't burn a chip properly. Turns out I'm just a dumb@ss. :mad2:
