countryboy69
Member
https://www.youtube.com/watch?v=tgIBgon4CU4&feature=plcp
Well I haven't been on here for a while. Been so busy I haven't had time for anything! I do apologize.
I got the dually back together finally with the 6.2 and an NV4500. All the mods I could throw at it along with cut pre cups and ported heads, intake, and manifolds and turbo housing. Luc clutch. Built my own driveshaft(first one!). Have basically rebuilt the whole truck.
Got her fired up and running and wow! She sounded sweet! For a whole 2 days........
Didn't want to push it for a little while so I just made a few short drives from the race shop to the house....run to the parts store...nothing far and was easy on it.
On day 2 my son and I headed to a ball game not 3 miles away. It felt very sluggish and I looked down to see the oil pressure dropping. I turned around and as it idled pressure was at 0. with a little rpm it would hold 15 to 20. So we limped it back the mile we was out.
Here is where it gets weird. It was definitely not a gauge problem. Pulled it out and checked pick up for coming loose or clogged. Nothing. Bearings was still good except for a few small scares on 2 cyls. I had a new set of Kings so I swapped them anyway, the scared ones was still good and was no reason to worry.
I have pulled the pump apart and found no issue. Shaft from cam was fine. pick up tube clean as well and clearance was perfect. I am an engine builder and build 900hp alky race motors that do NOT come apart! I can't find a single reason for the loss of pressure. I am lost! I blue printed the pump and checked the flatness of mounting on cap and pump. I have a new pump ready to throw in it but I am afraid it will not help. ANy of y'all seen this before on a 6.2? Im running the Hummer pan and pick up. Help! lol signed Confused in Indiana!
