racedaymechanic
Active Member
Ive been trying a few different set ups, what im looking for is better control of the WG by the spring, The arm is short on the HX series turbos so leverage is at a premium with the spring control, I built a new arm for my turbo with a Heim, Heres the Arm I have about 2 hours in it, the hard part is attaching it to the existing arm but I have a pretty good set up
Hers the Backside you can see how I made it to overlap the existing arm
All Together here I used a an washer with a spring washer under the clip to hold it tight
This is a little work I did on the divider not sure how much good it does but im sure it helps
