Diesel specifications---good info---please view!!!
6.5L
Old Iron Runner
Northwest Wyoming
I really hope this doesn't get relocated from this section! I want it to be viewed. But I started doing this diesel specifications project for a statistics class in college last year and just had some basic information in it. I decided today to update it to the best of my ability and post it for all to enjoy. Spent about 4 hours researching the rest of the information I didn't have today and organizing it. I know there is probably a few things wrong here and there but I believe for the most part it is correct. I found what I could to use. I use to look up some of these specs and always had to bounce between internet sites, so I figured why not organize it into once solid section. If you have comments, please be gentle :) I hope everybody enjoys this.
Diesel Statistics
FORD
6.9L IDI NA (1983-1987)
o Make: International
o Compression Ratio:
 1983-20.7:1
 1984-1987-21.5:1
o Bore: 4.00 inches
o Stroke: 4.18 inches
o Weight: ~860lbs
o Aspiration: Natural Aspiration
o Injection: Stanadyne Rotary Injection Pump
o Horsepower: 170HP
o Horsepower Peak (1984+): 170HP
o Torque: 330 ft. lbs.
o Torque Peak (1984+):338 ft. lbs.
7.3L IDI NA (1988-1994)
o Compression Ratio: 21.5:1
o Bore: 4.11 inches
o Stroke:4.18 inches
o Weight: ~920 lbs
o Aspiration: Natural Aspiration (1993-1994 w/ Turbo)
o Horsepower: 185HP (190HP w/ Turbo)
o Torque: 360 ft. lbs (388 ft. lbs. w/ Turbo)
7.3L Powerstoke (1994-2002)
o Compression Ratio: 17.5:1
o Bore: 4.11 inches
o Weight: ~920 lb dry
o Aspiration: Single Turbocharger
o Injection: HEUI (Hydraulic Electronic Unit Injection)
o Horsepower:
 (1994-1998): 215HP
 (1999-2001): 235HP
 (2002-2003): 275HP
o Torque:
 (1994-1998): 425 ft. lbs.
 (1999-2001): 500 ft. lbs.
 (2002-2003): 525 ft. lbs.
6.0L Powerstroke (2003-2007)
o Compression Ratio: 18:1
o Bore: 3.74 inches
o Stroke: 4.13 inches
o Weight: ~966 lbs w/oil
o Aspiration: Single Variable Geometry Turbocharger
o Injection: G2 HEUI
o Horsepower: 325HP
o Torque:
 (2003-2004): 560 ft. lbs.
 (2005-2008): 570 ft. lbs.
6.4L Powerstroke( 2008-2010)
o Bore: 3.87 inches
o Stroke:4.13 inches
o Weight: ~1,130 w/ Oil
o Aspiration: Twin Sequential Turbochargers
o Injection: HPCR (High Pressure Common Rail)
o Horsepower (Peak): 350HP
o Torque (Peak): 650 ft. lbs.
6.7L Powerstroke (Scorpion) (2011-current)
o Make: Ford
o Compression Ratio: 16.2:1
o Bore: 3.90 inches
o Stroke: 4.25 inches
o Weight: ~990 lbs dry
o Aspiration: Single Sequential Variable Geometry Turbocharger
o Injection: HPCR
o Horsepower:
 Intro: 390HP
 Peak: 400HP
o Torque:
 Intro: 735 ft. lbs.
 Peak: 800 ft. lbs.
DODGE
5.9L 6BT 12valve (1989-1998.5)
o Make: Cummins
o Compression Ratio: 17.0:1
o Bore: 4.02 inches
o Stroke: 4.72 inches
o Weight: ~905 lbs. dry
o Aspiration: Single Holset Turbocharger
o Injection:
 (1989-1993) : Mechanical VE Rotary
 (1994-1998.5): Mechanical Inline P7100
o Horsepower:
 (1989-1993) : 160HP
 (1994-1998.5): 215HP
o Torque:
 (1989-1993) : 400 ft. lbs.
 (1994-1998.5): 440 ft. lbs.
5.9L 6BT ISB 24valve (1998.5-2007)
o Make: Cummins
 (1998.5-2003): 16.3:1
 (2003-2007) : 17.2:1
o Bore: 4.02 inches
o Weight: ~1,150 lbs.
o Injection:
 (1998.5-2002): VP44 Electronic Rotary Injection
 (2003-2007) : CP3 High Pressure Common Rail
o Horsepower:
 (1998.5-2002): 235HP
 (2003-2007) : 315HP
o Torque:
 (1998.5-2002): 460 ft. lbs.
 (2003-2007) : 610 ft. lbs.
6.7L 6BT 24valve (2008-Current)
o Make: Cummins
o Compression Ratio: 17.3:1
o Bore: 4.21 inches
o Stroke: 4.88 inches
o Weight: ~1,050 lbs.
o Injection: High Pressure Common Rail
o Horsepower:
 Intro: 350HP
 February 2011 Upgrade: 350HP
o Torque:
 Auto: 650 ft. lbs.
 Manual Intro: 610 ft. lbs.
 Spring 2011: 800ft. lbs.
CHEVY / GMC
6.2L IDI NA (1982-1993)
o Make: Detroit
o Bore:3.98 inches
o Stroke: 3.80 inches
o Weight: ~700 lbs.
o Horsepower:
 Intro: 130HP
 Peak: 143HP
 Army:165HP
o Torque:
 Intro: 240 ft. lbs.
 Peak: 257 ft. lbs.
 Army: 330ft. lbs.
6.5L IDI TD (1992-2000)
o Make: Detroit
o Compression Ratio: 19.5:1-21.3:1
o Bore: 4.06 inches
o Stroke: 3.82 inches
o Weight: ~750 lbs
o Aspiration: Natural Aspiration and Single Borg-Warner Turbocharged
o Injection: Stanadyne Rotary Injection Pump (1992-1993 Mechanical DB2, 1994-2000 Electronic DS4)
o Horsepower:
 Intro:180HP
 Peak:215HP
 Fuel Miser: 120HP
o Torque:
 Intro: 360 ft. lbs.
 Peak: 440ft. lbs.
 Fuel Miser: 260ft. lbs.
6.6L Duramax
o Make: Isuzu
 LB7(2001-2004):17.5:1
 LLY(2004-2006):17.5:1
 LBZ(2006-2007):16.8:1
 LMM(2007-2010):16.8:1
 LML(2011-Current): 16.8:1
o Bore: 4.06 inches
o Stroke: 3.90 inches
o Weight: ~835 lbs.
o Horsepower:
 LB7(2001-2004):235HP
 LLY(2004-2006):310HP
 LBZ(2006-2007):360HP
 LMM(2007-2010):365HP
 LML(2011-Current): 397HP
o Torque:
 LB7(2001-2004):500ft. lbs.
 LLY(2004-2006):560ft. lbs.
 LBZ(2006-2007):650ft. lbs.
 LMM(2007-2010):660ft. lbs.
 LML(2011-Current): 765ft. lbs.
OK, there is definitely not a lot out there about the 4BD2's but this is what I managed to scrape up in about an hour.
Isuzu 4BD1/4BD2/6BD1Diesels
• Make: Isuzu
• Compression Ratio: 17.5:1
• Bore: 4.02 inches
• Stroke:4.65 inches
• Weight: ~728 lbs
• Aspiration: Natural Aspiration and Turbocharged (Listed with a “T” under horsepower ratings)
• Injection: Direct Injection for BD1 Motors, BD2 Indirect Injection
• Horsepower:
o 4BD1: 88 BHP
o 4BD1T: 105 BHP
o 4BD2T: 118 BHP
o 6BD1: 142 BHP
o 6BD1T: 163 BHP
• Torque:
o 4BD1: 181ft. lbs.
o 4BD1T: 240ft. lbs.
o 4BD2: 253ft. lbs.
o 6BD1: 289ft. lbs.
o 6BD1T: 375ft. lbs
Also I noticed an error I didn't catch. The 24 valve Cummins ISB Stroke should be 4.72 inches. Not 4.25 inches. No idea how I made that kind of a mess up. Sorry guys
I corrected the Cummins stroke.
This is a nice spec sheet and I can assure you that we all appreciate you putting it together. Not so sure it ONLY should be located in the 6.5 performance section since the 6.5 is a very small part of it. I am going to edit it some to add space to highlight the division lines between types.
Thanks again. I'm gonna see what the guys are wanting to do about location.
Mike
I just figured if it was in this section it would get read the most, and highlight away. It looked a lot better in Microsoft word haha no, go ahead, organize it however. If you can, correct the cummins stroke error please. thank you
Not trying to be too critical as this is good info, but where all did you get your info? I'm pretty good on diesel specs, and I found quite a few errors in your info. There are others I'm not sure about so I didn't put anything there.
Diesel Statistics
FORD
 1983-20.7:1
 1984-1987-21.5:1
o Bore: 4.00 inches
o Weight: ~860lbs
o Horsepower: 170HP
o Bore: 4.11 inches
o Weight: ~920 lbs
o Aspiration: Natural Aspiration (1993-1994 w/ Turbo) The turbo was optional from 92-94, not all of them had it.
o Bore: 4.11 inches
o Horsepower:
 (2002-2003): 275HP 01-03 was 255HP with the introduction of powdered metal rods.
o Torque:
o Bore: 3.74 inches
o Horsepower: 325HP 275HP for MD trucks
o Torque:
o Bore: 3.87 inches
o Make: Ford
o Bore: 3.90 inches
o Injection: HPCR
o Horsepower:
 Intro: 390HP
 Peak: 400HP
o Torque:
DODGE
o Make: Cummins
o Bore: 4.02 inches
o Injection:
o Horsepower:
 (1994-1998.5): 215HP HP ranged from 160 in 94-95 for auto's and 180 for manuals, to 180 in 96-98 for auto's and 215HP for manuals. Also 98 cab and chassis trucks were 230HP
o Torque:
 (1994-1998.5): 440 ft. lbs. Late manuals were 480 I believe.
o Make: Cummins
o Bore: 4.02 inches
o Injection:
o Horsepower:
 (1998.5-2002): 235HP 215HP for early auto's all the way up to 245HP for 6 speed manuals
 (2003-2007) : 315HP 235HP for 03 cali emissions and early 03 47RE auto's, 250HP for later cali emissions, 305HP for 03 manual and late auto's, and then 315HP for 04 +
o Torque:
 (2003-2007) : 610 ft. lbs. Early auto's were derated to 480, and the 03 engines were 555.
o Make: Cummins
o Bore: 4.21 inches
o Horsepower:
 Intro: 350HP
o Torque:
CHEVY / GMC
o Make: Detroit
o Bore:3.98 inches
o Weight: ~700 lbs.
o Horsepower:
 Intro: 130HP
 Peak: 143HP
 Army:165HP
o Torque:
 Army: 330ft. lbs.
o Make: Detroit
o Bore: 4.06 inches
o Weight: ~750 lbs
o Horsepower:
 Intro:180HP
 Peak:215HP
 Fuel Miser: 120HP
o Torque:
 Peak: 440ft. lbs.
6.6L Duramax
o Make: Isuzu
 LLY(2004-2006):17.5:1 The actual LLY ended in 05, 06 LLY's are deratedLBZ's and share almost nothing in common with the 05's.
 LBZ(2006-2007):16.8:1 LLY/LBZ
o Bore: 4.06 inches
o Weight: ~835 lbs.
o Horsepower:
 LB7(2001-2004):235HP 300HP for LB7's
 LLY(2004-2006):310HP 04.5 305HP, 05 310HP
 LBZ(2006-2007):360HP LLY 310 for trucks, 250HP for vans and 360 for LBZ trucks
 LML(2011-Current): 397HP Don't forget LGH at 335HP for cab and chassis's, and I believe the van is 275HP
o Torque:
 LB7(2001-2004):500ft. lbs. 550 official, but I believe 580 was an option as well for LB7's
 LLY(2004-2006):560ft. lbs. 590 for 04.5, 605 for 05
 LBZ(2006-2007):650ft. lbs. LLY was 610 for trucks, 480 for vans, and 650 for LBZ
 LML(2011-Current): 765ft. lbs. LGH 685, and van's is 485?
Yeah, I know there was a lot left out FERMANATOR and I was actually counting on that. I didn't know every detail and I thought that people would chime in with what I didn't have. I was hoping with all of this information and all the included information, that we could edit it and in the end have a very detailed sheet instead of what I put up. I figure I would get it started though and have people chime in along the way and like I said slowly edit it until we have covered everything we can. the more detailed it can be, the better, so don't be afraid to chime in people and then we can have the mods edit and revise until it is as accurate as possible. That was the point of doing this, and so we could all enjoy it and spread our knowledge further
And it was hard to get a lot of consistent information between all the sites I was going through which kind of explains why I did leave a lot out. I wanted it to be able to be built upon like I said. And I wouldn't say go as far as to call them errors, just things that need built upon :)
You've already done a great job. Pat yourself on the back man. Don't beat yourself up over a few errors or missing info. We'll ALL get it how it needs to be.
Good info, Cummings weighs 1150!!
Yup. Most bench racers don't consider this when comparing the ISB to the 6.X engines. So NO ISB powered 1/2 tons or sport-utes (OEM any way). And that is why the ISA (and the similar Isuzu) makes a lot of sense in Suburbans if you have got to ditch the 6.x. If you consider the power to weight ratio the 6.x beats the Cummings six, and its a bit cheaper to build (looking at the price premium between diesel Dodges and GMC's back in the day).
There is a 5.9 12V Dodge Ramcharger around here built by a diehard Mopar fan. Its 4x4 and has 3/4 ton axles. Looks perfectly stock. I badly wanted to do the same to mine, not so keen on that now.
I am sure the mods will put it as a sticky when we get consistent accurate information that is right. And I am not beating myself up over some errors. I knew there was going to be some. Like I said, I just did it to get the ball rolling and then other people can come in and correct it. I think it will be nice when it is done. FERMANATOR did a great job at correcting the information I posted, and I believe he is pretty right on with his information, so big thanks goes out to him as well. And even over time maybe add bits and pieces just beyond what was listed, such as cooling details, fuel rates, turbo designations w/years, etc. That stuff. I am not sure how readily available that information is though. Who knows. I think with just the information we got now, it is pretty nice. It would make a good reference for anybody who wishes to know.
There are a lot of very knowledgeable people here and I am glad that people are willing to help make this more accurate and enjoyable for everyone else.
