Hi Bruce I've been working gobs of hours so no time to be on at all, would not have been on tonight except I got a PM notice email I needed to reply to. Anyway drive pressure is a big part of the equation of what turbo efficieny is and IMO should be part of any evaluation along with IAT. When I started collecting data for the ATT R&D back when I started helping figure a better "mousetrap" than GM-8, I was flabbergasted how much drive energy/backpressure was created/required to attain boost at higher levels.
Ideally 1-1 ratio is what you want but there are some significant trades one has to consider to attain that or come close to it. GM-Xs quick spool off line but boosting ability drops off fast at higher boost levels, boost climbs but slowly by comparison to other turbos being toued with, also as boost climbs so does IAT.
What I did for collecting drive pressure was rather simple, drilled/tapped in main collector just below the turbo and got a cheap boost gauge (in $20 range the ricer kids are so proud of to add for cool factor ) and plumbed into the cab with 1/8" copper gauge kit. It aint the most accurate thing, but does allow me to collect some reasonably consistent real time observations of boost vs. drive press/back press the turbo/engine are dealing with., also lets me know when things like a rotten crossover or other exhaust drive issue is present.
I'm seeing age on my ole girl as seat of pant kick isn't what it was when 1st going to ATT 140K miles ago, valves & other stuff age/wear starting to show, new engine ready for install waiting for time for me to get around to doing it.
Thought Id suggest the el cheapo gauge route as an option for another pertinent data point, I just slaved mine in for temporary duty & have it hanging off my cup holder, I may make it purty/permanent one day, but if not a 1/8" NPT pipe plug into the manifold and I can remove the gauge/line altogether. Using copper as it won't melt like plastic gauge line could, and it dissipates heat fast enough I'm not melting stuff in the cab or gauge "innards"
BTW still need cables for burb & truck, just havent had time to work on either, but will eventually place the order I promise
Tim
