dyno
93chevydiesel
Virginia beach
so im gonna take the ol 93 6.5 to a speed shop that dynos diesels. has anyone else on here put there truck one a dyno if so what were your numbers like.
mods:
3"to 5" stack
cold air
rebuilt gm3 turbo
boost controller
nv4500 trans
fuel turned up
4.10 gears front and rear
mods:
3"to 5" stack
cold air
rebuilt gm3 turbo
boost controller
nv4500 trans
fuel turned up
I have no idea about the dyno.
But, what kind of difference did it make when you turned up the pump?
With a 3in downpipe to a 4in exhaust, a DB2831-4911 turned up a quarter turn, home-made wastegate controller set to 17psi on a GM-3,and a AFE Stage II intake, I made 203rwhp at 3800rpm and 331ft lbs or torque at 2800rpm. This was a 1993 Regular Cab Long Box K3500 Single Rear Wheel with 4:10 gears and a NV4500. I think depending on where you are at and all that, you can expect close to that.
thats not bad ya i have been wanting to run it since i bought it. most my buddies have 7.3 and tend to talk down to my lil ol 6.5. i no it cant compete with the 7.3 jus wanna show that it can be a strong diesel also. and for a lil pride in my boat to say i have built this truck
Im curious what your numbers would be with maxed fuel screw and bigger more efficient turbo.
actualy just so you know, i ordered new 2300psi pop injectors, and after i get them in i am going to do some fuel tuning with the ATT I got now and hit the dyno, so i may be able to calm that curiosity soon haha
Yeah, I will post up. I still got some things to figure out but I will be making a few dyno runs here in the future with some mods to come for good comparisons so I won't leave you guys in the dark
We are just organizing for our first dyno run, would like to have some base #'s so we are able to attain if we are going in the right direction with our current build.
Yeah, I have been keeping track of such things. Well now you got an idea of where a mildy modified mechanical 6.5L is at with the usual modifications (fuel, air, exhaust). I won't let you in on all the planned mods, but I will be planning on using water injection if that gives you any idea of where I am going to be going with fueling :) stay tuned
