The dual housing definitely makes ip adjustment more difficult. No argument there. I don't do it very often though so it doesn't bother me.
The single is reported to cut off recirculating flow in the engine when open, forcing all the coolant to pass through the rad.
Camps are split on whether this is good or bad.
Some think forcing all the fluid through the rad aids in cooling, others think maintaining some flow through the heads and the rad reduces localized hot spots.
Gm installed the dual stats as the single was "supposedly" unable to flow the full rate of the upgraded water pumps.
You have to decide for yourself after looking at the info available. Google actually turns up a fair bit of reading on the subject.
I know what side if the fence I'm on to the subject, but won't put it out there....too many strong opinions on both sides.
I believe I remember reading Heath was fine with the single or dual but don't quote me on that.
Honestly, you're probably good either way....
Sent from my iPhone using Tapatalk
