gmctrucksrock
gmctrucksrock
ok bought this gem 1000.00 barley got it home, wouldn't start warm and smoked like a chimney, so has 235,000 could be old slope rig, so pull tank about 3 gallons of ice/water removed cleaned sock blew lines out pulled filter and housing removed cleaned replaced, had old injection pump laying around off a n/a 6.5 so turned up screw 1/2 turn maybe little less, got whole thing back together runs great smokes tires, makes my suburban seem like a turd, no real "black smoke" that i can see as in un burnt fuel had to tell is -13, at this temp every rig has a white cloud behind it, put lift pump on relay so turn key and its on. went thru every glow plug and tested one by one 4 bad 4 good replaced with good old ones it had tested.
question?
1. all of a sudden after doing all of this she seems to be more of a knocka knocka diesel definitely louder why?
2. next glow plug light wont come on why?
3. in the process of n/a injector pump to 93 td version replaced black electrical unit on passenger side of pump n/a version had vacuum hose unit this one has plug and wire I put in same spot it is adjustable now i seem to not have over drive? why is this a sending unit ti transmission?
4. looking at turbo it says gm3 on tag is this stock for this year seems different than my 95 suburban?
Thanks for any input
question?
