quick update, just checked the 1000 /2000 manual (techran manual "GM") for the TCM to funktion, it needs following:
1/ throttle position sensor- standalone or the pedal modified on the 98 ext cab dually to take the 2nd TPS. should be a no brainer!Nuts and bolts..
2/ engine speed sensor is already in allison bell housing.
3/ hook up neutral safety swith so it does not start in gear//run over anybody, but a must is a exception to the safety swith, if OBUMMER is in the back of my dually , run him over without my knowledge!!!!!!
I understand the thought on the 4LO80E, I have one here, that is the trans that I was going to install i, but by the time I get a real rebuild Raptor or etc. with all the right stuff in it to be able to haul 18000 lbs every once in a while it's 4 grand. I could do the rebuild myself but it would be my time and 1700$ in parts. I am booked with busconversions/DD 60 engine repowers with the B500 and ZF in back of them so I have no time to do my own. I rebuild the big Allisons and the ZF,s and pump up the Series 60's to 720 HP. I do the work for the racers, who want to be the first out of the center of the ring with their rigs (it's a status symbol among them!)
Let me touch bases on the 6.5 TDS in short for turbodiesel! When I don't have the answer to a problem on my engine builds or trans build, I go to the allison and detroit diesel engeneers, so in short the two companies that we have that are still in business and doing good and who I trust, Peninsular, and Bill Heath. Bill runs a 6.2 TDSL with 40 some psi boost with water injection, and runs the GM C1500 or 2500 down the saltlake flats @ about 160 MPH 2X 3 miles and after that he can drive it home on cruise controll if he would want to. The only nonstock items on his 6.2 TD is the computer and the camshaft by comp cams and a few minor things that are ARP head bolts and ARP main bolts.
So I bought his kit for my 1998 Ext Cab 6.5TD with his words that after working with GM as their skunk works in the beginning he came up with this kit, if you install it into a 6.5 TD, the normal mildly tuned Duramax con't hold with it........,,, and your 6.5TD will do everything right . Bill is a man of his word, so if it is not right I will let you guys know about it! My reason for sticking with the 6.5TD is that I am retired military and the Hummve saved my AxS a few times. Also the the mechanic from the Chevy garage drinks a beers with us and filled us in on the duramax. If you need to pull the turbo or work on any part of the engine the CAB has to be pulled off,,,, that is insanity to the max and that is not my cup of tee.
I love the looks, the allison ride of the duramax and the comfortable features of the cab. but the 40k and not being able to work on it on the side of the road leaves me out of the buying mood (or financing mood!)
Please do not be insulted if you drive a Duramax I just can't afford to be stuck on the side of the road and not being able to work on it, with a load of farm animals about 18.000lbs. As we all know it would be very expensive to get 2 tows, our animals need food and water or they die...
this is my story and I'm sticking to it!!!!!!!!!!!!! Unless you can convince me otherwise!!!!!
