Ok I have all replayed but Im new so LOST THE THINK Here is again: Hola, Sorry for the lost have go to Mexico City El Monstruo Means DF. Ready now.
Do you have a sensitive throttle? A: A little Bit
you say you are tech, what kind of diagnostic tools do you have at your disposal, that you are using for your readings ? A: Genysis 2.0, Auto enginuity Latest Version with enhaced Chevy, Ford, Dodge. Snap On No thanks.
You have no way to set the desired and actual injection timing, aside from a different PCM, its programmed in. A: Agree its totally true no way to modificate unless reprogram. wich you need a diferent software and a tool to put in the PCM.
Also unless you set the TDCO yourself, no knowing if that saved value is accurate. A: True and yes done by my self Took 2 hours and for shure its well done.
I have found that 9-10 degrees is a good place to set the idle injection timing A: Lets test It.
The scanner may be working though, and if that is the case, what can cause the timing to read that low is when the crankshaft position sensor (CPS) and the Optical Sensor (OS) in the Injection Pump (IP) are not actually in sync. Like if the CPS is installed incorrectly, which can happen if the mounting tab of the sensor breaks off, or some have a metal mounting tab that can pop off and be put back on wrong, so the sensor goes in out of rotation. A: 3 months ago brand new timing Kit by dinagear, (Found inly one here in mexico buyed by ORMA Autopartes Call to dynagear dealer in mexico they gave the info ONLY ONE KIT IN ALL MEXICO) New wather pump BW, All in place for shure. Optical sensor brand new from stanadyne (Oh yea cost lotttttt damn work cause the stealer Stanadyne sayd "Oh yes we have the sensor but you need to bring the IP and we fix it, The cost: Very cheap man 1400dlls" ONLY WOW THESE IS A DAMN OFFFFFEEEEERRRRRRRR,) So my pieces provider in Guadalajara Jalisco that also is my friend get the sensor from the stanadyne stealer (The same they are friends too) And I Put the new one in the IP, By the way get to these point cause some stupid guy how fix the chassis have the wonderfull idea to gave a litle just a litle wash to the heart of my beast, ohhhh yeaaaaahhhhh with a KARCHER mmmmhhhhhmmmmm, and gues what The wires below the IP and the Intake, get fried. these gave me the gift of replace the OPS cost 700 Dlls and 3 days of work, yes redesign the wires all from the Fire wall to sensors an stuffs, Past it from top of the Intake And the pump enlarge the wires to the PDM and relocate in the left cowl a side of the ABS Pump-module. (I Know need new place to put it)
If you dont have a potential spun CPS problem and you set your TDCO then you would do real good to get yourself an aftermarket programmed PCM, such as from WalkingJdesigns.com, the Kojo programming, or Heath. A: Man THESE IS MEXICOOOOOOOOOO. No PCMs reprogramed, And Dont credit card so Cant buy it from Infiernet, And UPS is the only one bring to mexico the things and if the PCM cost 400Dlls guess what, total 1000Dlls here in mexico. in your opinion what should I do free gift 500Dlls to UPS???????
