So what is the tunercat then ? I was poking around westers garage, lots of stuff. BTW they have a realtime program for 6.5TD
Tunercat II is the software interface, like efilive for duramax. It also requires it's special hardware interface to connect to the trucks OBDII port.
In order for tunercat II to understand the calibration written in the PCM, it needs a
vehicle
definition
file otherwise known as a VDF. It's like tunercat speaks English and the PCM speaks french, the vdf translates so they are both speaking English.
Westers offers tuning software for the 6.5 and duramax, but it costs 1800 bucks. It's essentially tunercat II with the VDF's already in it. While 1800 bucks is outside of most folks reach with these old trucks, Lyndon has graciously offered his 6.5 VDF's for sale (99 bucks each) for those with tunercatII already. It's a pretty tight knit community (tunercat II owners) so there's been a gentlemen's agreement on not redistributing it (well, legally buyers can't distribute it either).Tunercat is no longer available for purchase (unless you find a back door like I did
)so everyone pretty much knows who has what.
Westers offers real time tuning for the 411 PCM and LB7 PCM's.
Westers tuning software cannot do real time tuning on the 6.5, I've talked to Lyndon on this.
Oddly enough, the real time tuning PCMs supported by westers are the same PCM's that Roadrunner from Moates supports. Westers web site even directs you to Moates Roadrunner emulator site for the drivers. But it's not a simple plug into the OBDII port and go at it real time. The PCM circuit board has to be modified and more hardware installed. Basically, the flash chip is desoldered from the surface mount board, then the emulator header is soldered on, then the emulator is installed in the PCM. I have the hardware sitting on my shelf waiting for the day I do an LB7 swap like Ferm did, but that's another discussion for another day.
Unfortunately, the architecture of the 6.5's PCm is significantly different from the LB7 PCM (and the 411) so real time tuning is not possible through Lyndon right now. That's what I'm working on....
What I'm talking about is a blending of supported hardware and software between obdI and OBDII to get some rare support for our "bastard child" PCM's.....
