great white
Well, my Dodge towing mirrors showed up today.
After a few reader requests when I mentioned it in my truck's build thread, I've decided to do a seperate full install thread.
Since I figured it's for GMT400's, this forum is the best place for it. If not, a mod can feel free to move it.
This will be for a full install of the dodge "flippable" towing mirrors, circa 1998-2001. In case you're wondering, reports indicate that mirrors newer than this will not fit the door of the GMT400. The mirror base is bigger on newer dodges and the rake of the widow is different. They just won't fit if newer than dodge 2001/02 (crossover year) gents.
My install will be full power and heated.
For reference, factory mirrors in this style could only be had in manual. "Burning Oil" has an install of the factory manual mirrors on the forum elsewhere if you're going that way. Or just read through the thread and once I get to the physical install on to the doors, stop there if you're using manual mirrors.
But if you want power mirrors in this style, you have to go aftermarket. "Clear VU" is a popular choice with most buyers, I went with an ebay set. Name on the box is "Fortress", made in Tiawan and I paid right around 300 bucks to my door for a set of left and right (shipping to Canada is always more than what you would expect gents).
Yeah, I can hear the peanut gallery already:
"Foreign junk!" "Buy USA!"
Well, these appear to be good, solid, heavy units. For a good price no less. Time will tell though once I get them on the truck for a while. First impressions are really good though.
So, let's start off with a comparision of old and new:
Side by side. Dodge mirrors folded. The increased mirror area is evident even from the front:
They're bigger, but not foolishly so.
The stock GM mirrors are completely outclassed for rearward visability in towing "mode":
Bigger, but still manageable.
GM mirror pretty much dissapears behind the dodge:
Shot with the GM in front (to give it the advantage of perspective view) and the Dodge mirror still outsizes it by quite a bit:
Again, no comparison in "towing mode":
Shot from the top:
Dodge mirrors have quite a bit of "sweep back" compared to the GM units. Also not the difference in the mounting studs. Dodge is much longer. We'll have to deal with that later.
A side by side of the mounting area:
Geez, that's really really close! You can also see there's going to be a need to re-drill the mounting holes in the door skin.
Power and heat connectors aren't even "in the ballpark":
A bit of work with a few wiring diagrams and a couple passes with a soldering iron and shrink wrap will figure this out. There'll be a seprate post in this thread when I get it all sorted. Shouldn't be too hard to figure out...
The mounting angle with the mirrors resting flat on the table:
Bit of a difference there eh? Nah, that's not a realistic view since they should be mounted on the truck, not sitting on the table. Let's have a look at the angles with the mirrors both leveled out in the "viewing plane":
Still not perfect, but more than close enough to work with.
That's the first installment. Watch this space for more as the install progresses...
Shot from the top:
