there is a pinhole on the closed side,sometimes it is plugged,rendering it useless.
they are easy to test.
Take the CDR off the engine
1) hold the valve cover tube closed
2) suck hard on the turbo tube,you should feel the diaphram close.If not,the Thing is toast(crack or hole in the diaphram)
3) put a finger on the pinhole,keep it there.
4) release both tube openings
if the diaprham holds in closed position with the pinhole plugged and opens after pinhole is open ,the thing works just fine.
GW,you may have to much blow by on that old boat,even a new CDR cant handle that,look in my sig for solutions. The 95 version is the better one,cheaper too.
