great white
So, my 6.5 has a fair bit of blowby. It also has a fair bit of oil in the bloody intake/turbo.
I've done the water test before and if I recall it pushes the water down about 1/8-1/4 inch at idle but pulls it up about 4-6 inches at 2000. IIRC, that's too much vacuum at 2000 rpm, which indicates a bad CDR.
I'm about to go out to do a redo the "water check" to confirm what I remember.
I'm thinking the CDR is pooched in addition to a.......ahem...... "well seasoned" engine.
Couple Q's:
1. Anyone think a new CDR may lessen the oil in the intake? (I doubt anything will eliminate it)
2. I know the purpose of a CDR is to limit the vacuum at higher RPM's in a turbo diesel. But, how is it constructed internally? (IE: butyl rubber diaphragm and spring, shuttle valve, etc). Or, what fails inside a CDR if that's a better question....
3. Any point in trying to clean it? I think I've read soaking overnight in diesel or kero sometimes cleans a sticking CDR. Although, mine seems to be so soaked in fresh (well, sooty black) oil, I'm leaning more towards a failure than "gunked up".
4. Or, am I just experiencing the symptoms of a worn engine and the cdr just can't cope with it?
Just looking for some good input before I order one and plunk down a 100 or so bucks.....
Couple Q's:
