Problem Child
Non Diesel mechanic
About a month ago I had to replace the lift pump in my 95 Suburban in a O'Reilly's Auto Parts parking lot.It has ran fine ever since but on shutdown I have been hearing the lift pump miss a little and it almost sounds like the noise is at the engine instead of on the rail???
Well Friday I drove about 20 miles to a pawn shop and I noticed the engine running a few degrees warmer than normal.
Of course it was about 96 degrees out and I was running about 75 all the way,so I didn't think much about it.BTW...I have the high output waterpump and 9 blade fan.
When I came out of the pawn shop I cranked the truck like normal,running fine,put it in gear,everything's fine, and then out of nowhere,it starts shaking badly.I turned off the AC,put it back in park and revved it up. Still shaking, I slammed her in gear and took off.
It shook at low speeds but not as bad when I hit 70 on the highway. I came on home and every time I slowed down it would shake.
I checked the codes when I got home and it read a 92,93,94.....Cylinder Balance Faults.
Saturday I started working on the truck.
I first checked the lift pump. Everything seemed fine according to the lift pump test,although I didn't check fuel pressure.There was some black stuff(??)coming out of the drain line from the valve. It doesn't seem to be solid because you can touch it and it desolves.
Next I changed the fuel filter.Cranked the truck, and still shaking. After that I changed the fuel line coming from the the filter canister to the fuel injection pump and also the line going to the T valve but did not change the 3/8 line that goes from the steel line to the back of the filter canister.Cranked the truck again and still shaking.
Well after I changed the lift pump last month,I decided to check the old pump with a battery and It still seemed to be working ,so I decided I would stick it back on the truck.
The missing lift pump noise that seemed to be coming from the engine went away, but the truck is still shaking. I also did the lift pump test on the (old) pump and according to the test,it's fine.....again,I didn't check it with a pressure gauge.
So.....now I move to the PMD.My PMD is mounted behind the front
bumper with an extended harness and heat sink.I stuck my old PMD back in and still shaking.
Today I took the lift pump that I put on a month ago back to O Reilly's and exchanged it for a new one,came home,put it on and still no change.What's next???
