Well, here was today's fun.
Ran into a couple of snags today. Nothing that couldn't be fixed, but it just added some time to the process.
And, I have a good WHOOPS picture for ya.
So here's how today went down.....
Got the tank back in....no leaks at the fuel sump, so I'm happy with it. Can't plumb the supply line to the FASS until I get a few more fittings. Didn't plan on needing that extra 90* hose end, so gotta wait for that to get here. Cleaned up all the fuel lines and wiring around the tank and FASS....removed the oem supply line totally.
Now, here is where we ran into the first snag. When we went to put the bed back on, one of the bed supports was right on top of the new battery box and the bed wouldn't seat all the way. So, the bed got introduced to Mr Plasma and that solved that problem.
Now, here's the next snag we ran into today. I installed the GN hitch on the frame, cut the hole in the bed at 45.5" from the rear edge of the bed (like the instructions called for on the short bed) and when we went to put the bed on, it wasn't lined up with the hitch.....the hole was almost 2" too far forward.
Sooooo, had to do some cutting, welding, grinding and patching on the bed floor. No big deal, it'll get ground down and re-Linex'd and it won't even be visible.
So here's my WHOOPS for the day.....don't say I didn't share the bad along with the good.
The gap from the hole saw was too wide to tig it in real nice, so had to bump it with the mig. I'll get ground down and re-linex'd and you'll never know it's there.
