great white
I've noticed everyone "in the know" on this board seems to recommend removing the vacuum pump and installing a "turbo master".
I guess the big question is "why"?
Why not just replace the Vac pump and get another couple hundred thou KM's out of it?
I understand the elimination of another rotating/wearing component (pump) and I understand the need for a shorter belt, but I have some specific questions:
1. My truck is a 98 L65. My understanding is the PCM controls/monitors the boost and when it comes on and off. Obviously, this function will be lost with a TM. Is this and issue for the PCM?
2.What about fuel MPG? what effects are there? (less, more, same, etc)
3. Will it effect engine life? (ie: overboost, never backs off boost, etc)
4. Engine performance effect?
5. What is the advantage of a TM over the stock system?
6. How does a TM operate? It seems to be a fixed rod, so does it deliver the same boost all the time or is is dependant on gas exhaust speed for increasing boost? If so, are boost levels linear?
7. Do you absolutely need a boost gauge with a TM? I only ask because I haven't installed a boost gauge yet (funds are tight right now, egt will most likely come first).
I'm just looking to formulate a plan for moving forward on this old girl. Yet to be explored is supplemental oil filtration (FS-2500/centrifuge/etc), supplemental fuel filtration/water separation/fuel heater, gauges, cooling system filtration, etc etc etc.......
Obviously, a lot to be done that will takes years to complete. just doing the research right now to have it all in place when my 404 000 km engine "gives up the ghost"....hopefully, not for several years yet!
