Hey, one other thought - Before you pull the bed/tank/FSU, check your harness one last time to be sure it's not a wiring problem. It may seem like a hassle, but I gotta tell ya Len, spending the time/energy/$$$ to replace the FSU only to find out that's NOT the problem is gonna be a serious butt kicker. :mad2: At this point, one more hour spent making sure you're on the right track is a small thing. :thumbsup:
Remove your instrument panel and disconnect the harness at the back of the IP. Since you already have the harness disconnected at the FSU, the gauge wire to the FSU is now electrically isolated. OK, now test the wiring for the FSU:
- Check for continuity from the IP harness pin to the FSU harness pin. You should read continuity, since it's a solid wire connection from the gauge to the sending unit.
- Now, ground one probe, then check for continuity from the IP harness pin to ground. You should see no continuity - wide open. This checks for a ground from the gauge back, and will tell you if the harness is grounded somewhere on the frame or sheet metal.
- Leave one probe grounded, and check for continuity from the FSU harness pin to ground. Again, you should see wide open. This checks for a ground from the sending unit forward. It's sort of a repeat, but it's a good double-check.
- Last, check for continuity from the 'Ground pin' at the FSU harness to ground. Here you should see continuity, since that pin is wired to the chassis ground.
OK, for these four steps, you should have seen continuity from pin to pin and from the FSU 'ground' pin to ground. There should have been NO continuity from either 'gauge' pin to ground. If this checks out, your harness is good. :smile5:
You can also do one final test on the FSU itself, before you pull it. You need to have some kind of idea how much fuel is in the tank. Connect your meter to the two harness pins at the FSU. You should read somewhere between 0 and 90 ohms:
- 0 - 3 ohms if the tank is empty
- 45 ohms at half-full
- 88 - 92 ohms if full
- Reconnect the harness at the FSU, go to the IP harness and repeat the test. Ground one probe and check for resistance at the IP pin. Your reading should match what you saw at the FSU.
I realize this is review; you're just double-checking to save some $$$. If the meter readings don't even come close to matching reality, it's the FSU for sure. If you decide to pull it, you can re-check the FSU on the bench. It'll also be a great time to replace or remove the sock and to also check the inside of the tank for cleanliness/grunge/fungus. A hassle, but time well spent. :thumbsup:
